<p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";">Tolerance V5.4是一款计算机辅助设计软件。该软件的宗旨是最大程度减轻机械设计工程师的工作强度。软件的开发目标是提供机械设计中各种机械公差的查询以及简单的相关计算。该程序VER5.4版有以下几个模块及功能:<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>1)以中国国家相关标准为基础,在同一界面下实现了尺寸公差与形位公差的查询。<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>2)GB10095-88渐开线圆柱齿轮 精度查询。不查标准就能获得所有的渐开线圆柱齿轮工程图参数;渐开线圆柱变位齿轮的辅助计算(VER3.0新增功能)。<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>3)最新GB平键、半圆键、楔键、薄型平键、矩形花键规格、尺寸、配合公差、形位公差、粗糙度检索查询。(VER4.0增加功能)。<span style="mso-spacerun: yes;"> </span><p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>4)GB10085-88圆柱蜗杆蜗轮匹配与尺寸计算,GB10089-88圆柱蜗杆蜗轮精度查询。蜗杆蜗轮齿坯形位公差、粗糙度查询。(VER5.0增加功能)。<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>5)渐开线圆柱齿轮强度校核;圆柱蜗杆蜗轮强度校核;各种键强度校核。(VER5.0增加功能)。<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>6)设计结构要素查询,包括螺钉沉孔,退刀槽,轴孔挡圈槽等十类结构要素。(VER5.1增加功能)<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>7)三角V带传动及带轮公差设计,包括普通V带、SP系列窄V带和N(V)系列窄V带自动设计查询。(VER5.2增加功能)<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>8)O型橡胶密封圈沟槽智能设计与公差查询。 (VER5.3增加功能)<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 40pt; mso-char-indent-count: 4.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";">9)常用材料热处理、用途及性能查询;材料密度查询。(VER5.4增加功能)<p></p></span></p><p></p><p></p><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><span style="mso-spacerun: yes;"> </span>10)Solidworks二次开发模块,动态实现零件和装配文件的属性获取与标注。动态实现Solidworks工程图文件的一键傻瓜批量打印功能(VER2.0、5.32增加功能)。(VER2.0增加功能)。<p></p></span></p><p></p><p></p><p><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman"; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-bidi-font-family: "Times New Roman"; mso-ansi-language: EN-US;"><span style="mso-spacerun: yes;"> </span>该程序作为CAD/CAM的辅助工具,在代替传统纸制介质的同时,力求提高机械设计人员的工作效率和质量,是工程设计人员不可多得的工具。</span></p><p><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman"; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-bidi-font-family: "Times New Roman"; mso-ansi-language: EN-US;"></span></p><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman"; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-bidi-font-family: "Times New Roman"; mso-ansi-language: EN-US;"><p class="MsoNormal" style="MARGIN: 0cm 0cm 0pt; TEXT-INDENT: 20pt; mso-char-indent-count: 2.0; mso-char-indent-size: 10.0pt;"><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman";"><a href="http://yhj1001.go1.icpcn.com/Data/Tolerance_SetupV5.4.exe">http://yhj1001.go1.icpcn.com/Data/Tolerance_SetupV5.4.exe</a>(</span><span lang="EN-US" style="FONT-SIZE: 10pt; FONT-FAMILY: 宋体; mso-hansi-font-family: "Times New Roman"; mso-fareast-language: ZH-CN; mso-bidi-language: AR-SA; mso-bidi-font-family: "Times New Roman"; mso-ansi-language: EN-US;"><a href="http://www.skycn.com/soft/15294.html">http://www.skycn.com/soft/15294.html</a></span></p></span>
[此贴子已经被作者于2006-11-2 21:59:16编辑过]
